Configures FTP file synchronization for NVPP and VMMAP files.
| primary | secondary | Specifies the whether you are configuring the primary or secondary FTP server. |
| ipaddress | Specifies the FTP server IP address. |
| vr_name | Specifies the VR that is used to access the FTP server. |
| seconds | Specifies how often the switch updates the local files that are synchronized with the FTP server. The range is 40 to 3600 seconds. |
| path_name | Specifies the path to the repository server files from the FTP server root directory. The default directory for repository server files is: pub. |
| user_name | Specifies a user name for FTP server access. If no username is specified, the switch uses user name anonymous. |
| encrypted | This keyword indicates that the specified password is encrypted. |
| password | Specifies the password for the specified user name. |
Refresh interval: 600 seconds.
Some jitter is added to the refresh interval period to prevent all switches from downloading files at the same time.
The following example configures the switch to refresh the VMMAP and NVPP files from primary FTP server ftp1 every five minutes:
# configure vm-tracking repository primary server ftp1 refresh-interval 300
This command was first available in ExtremeXOS 12.5.
Support for specifying an FTP user name was added in ExtremeXOS 12.6.
